[原创] AutoForm 4.20 终于登录中国拉
kofkillerLv.8 显示全部楼层 发表于 2009-2-14 13:50 |阅读模式 打印 上一主题 下一主题
其他内容
:30( :76( :84) :86)
刚得到消息,AF4.20 终于登录国内啦。。。不知道什么时候能用上。。:87)
先给大家带来新版本的消息吧。。
Accurate OneStep-based flange development: Besides geometrically-based flange development, the new version also offers physically-based flange development. This new option is enabled by using the OneStep solver technology and significantly improves the accuracy of trim lines. In addition, it allows the development of flanges with holes inside and the development of multiple flanges.
More efficient springback compensation: Version 4.2 has an optimized algorithm, which is developed in order to increase surface quality and speed up springback compensation. It also contains new options to define the areas for compensation and manually control these areas.
Import of various native CAD files: Within the AutoForm version 4.2, users can now also import the native files generated by CATIA V4, CATIA V5, Unigraphics NX, Pro/ENGINEER, I-DEAS and SolidWorks. There is no longer any need for data conversion and related risk of data quality loss. In addition, a specially developed export file format can be directly imported by Tebis.
Hydroforming process – new stage concept definition: Increasing complex part geometries often requires the preform forming step after the bending and before the hydroforming process. Version 4.2 provides stage concept definition for the hydroforming process starting from bending and preforming to hydroforming. In addition, this version includes the definition of preforming tools. The new concept significantly improves the part quality, increases manufacturing efficiency and reduces the tool wear.
以上转自Autoform官网。
懒人就不翻译了。。
简单说来,这次的新版本有4个大变化。。
1,diedesign 的展开翻遍线更加精确,Autoform公司优化了算法,当然实际如何需要大家测试。
2 ,优化回弹补偿模块,面更好,速度更快。
3,可以导入多种CAD格式了,包括CATIAV4,V5,以及UG等等。。。。爽。。
4,优化液压成型。。。
精彩评论54
dyne2Lv.8 显示全部楼层 发表于 2009-2-15 09:13
正版用户就是好呀~!:78(
小点儿Lv.12 显示全部楼层 发表于 2009-2-15 16:30
不知道我能用到不。。。:87)
jine_0Lv.12 显示全部楼层 发表于 2009-2-15 19:31
你带来的可是好消息,感谢通知大家顶你。
huhubabaLv. 显示全部楼层 发表于 2009-3-3 17:53
好消息啊
zfhwyzLv.2 显示全部楼层 发表于 2009-3-6 08:19
期待上传
lzl_86Lv.2 显示全部楼层 发表于 2009-3-10 12:23
有没有盗版的,下来我学习一下
bbcLv.4 显示全部楼层 发表于 2009-3-10 12:43
正版都没有,估计盗版还早吧。。
dyne2Lv.8 显示全部楼层 发表于 2009-3-10 18:42
ms盗版已经有了
1387980441Lv.8 显示全部楼层 发表于 2009-3-31 12:52
AF4.20的功能更加强大了,计算精度也肯定提高了不少
