• 发帖数42
  • 粉丝4
[求助] 求各位大神指导小弟,练习自带实例3回弹补偿时Aborted
wanglieliangLv.2 显示全部楼层 发表于 2013-11-3 20:19 |阅读模式 打印 上一主题 下一主题
完全按照应用手册做的实例3,在回弹补偿运算时刚一会就Aborted,运算信息如下:求大神指导一二,万分感激!!!
expanding   memory to     2819551
expanding   memory to     2849048
Memory required to process keyword     :      2849048
contracting memory to           1 end of keyword reader
LS-DYNA will perform a structural only analysis
                         ls-dyna ls971s.50638 R4.2    date 02/04/2009
*** Warning reset D3PLOT output interval from 0. to   5.0000E-03
expanding   memory to        2209 material, node and element data
expanding   memory to        2284 material properties
expanding   memory to       36743 element data
expanding   memory to       50910 gradient of damage data
expanding   memory to      219462 user control for contact interfaces
expanding   memory to      219464 for boundary cond. vectorization
expanding   memory to      224398 arbitrary element numbering input
*** Warning warpage angle of element 24 is 9.0007E+01 degrees
*** Warning warpage angle of element 25 is 9.0007E+01 degrees
*** Warning warpage angle of element 26 is 9.0007E+01 degrees
*** Warning warpage angle of element 27 is 9.0007E+01 degrees
*** Warning warpage angle of element 29 is 9.0007E+01 degrees
*** Warning warpage angle of element 36 is 9.0007E+01 degrees
*** Warning warpage angle of element 38 is 9.0007E+01 degrees
*** Warning warpage angle of element 50 is 9.0007E+01 degrees
*** Warning warpage angle of element 56 is 9.0007E+01 degrees
*** Warning warpage angle of element 57 is 9.0007E+01 degrees
*** Warning warpage angle of element 59 is 9.0007E+01 degrees
*** Warning warpage angle of element 69 is 9.0007E+01 degrees
*** Warning warpage angle of element 70 is 9.0007E+01 degrees
*** Warning warpage angle of element 71 is 9.0007E+01 degrees
*** Warning warpage angle of element 72 is 9.0007E+01 degrees
*** Warning warpage angle of element 76 is 9.0007E+01 degrees
*** Warning warpage angle of element 77 is 9.0007E+01 degrees
*** Warning warpage angle of element 78 is 9.0007E+01 degrees
*** Warning warpage angle of element 79 is 9.0007E+01 degrees
*** Warning warpage angle of element 80 is 9.0007E+01 degrees
*** Warning warpage angle of element 81 is 9.0007E+01 degrees
*** Warning warpage angle of element 85 is 9.0007E+01 degrees
*** Warning warpage angle of element 86 is 9.0007E+01 degrees
*** Warning warpage angle of element 87 is 9.0007E+01 degrees
*** Warning warpage angle of element 92 is 9.0007E+01 degrees
*** Warning warpage angle of element 93 is 9.0007E+01 degrees
*** Warning warpage angle of element 94 is 9.0007E+01 degrees
*** Warning warpage angle of element 100 is 9.0007E+01 degrees
*** Warning warpage angle of element 101 is 9.0007E+01 degrees
*** Warning warpage angle of element 102 is 9.0007E+01 degrees
*** Warning warpage angle of element 103 is 9.0007E+01 degrees
*** Warning warpage angle of element 106 is 9.0007E+01 degrees
*** Warning warpage angle of element 110 is 9.0007E+01 degrees
*** Warning warpage angle of element 111 is 9.0007E+01 degrees
*** Warning warpage angle of element 112 is 9.0007E+01 degrees
*** Warning warpage angle of element 115 is 9.0007E+01 degrees
*** Warning warpage angle of element 116 is 9.0007E+01 degrees
*** Warning warpage angle of element 117 is 9.0007E+01 degrees
*** Warning warpage angle of element 126 is 9.0007E+01 degrees
*** Warning warpage angle of element 129 is 9.0007E+01 degrees
*** Warning warpage angle of element 130 is 9.0007E+01 degrees
*** Warning warpage angle of element 133 is 9.0007E+01 degrees
*** Warning warpage angle of element 141 is 9.0007E+01 degrees
*** Warning warpage angle of element 142 is 9.0007E+01 degrees
*** Warning warpage angle of element 144 is 9.0007E+01 degrees
*** Warning warpage angle of element 148 is 9.0007E+01 degrees
*** Warning warpage angle of element 151 is 9.0007E+01 degrees
*** Warning warpage angle of element 163 is 9.0007E+01 degrees
*** Warning warpage angle of element 177 is 9.0007E+01 degrees
*** Warning warpage angle of element 181 is 9.0007E+01 degrees
*** The above message exceeds 50 times
     Further printing will be suppressed
     You can change the limit at field 4 of card 2 of *CONTROL_OUTPUT
*** Warning element ID     862 is a very badly
     shaped element-possibly unstable.  Possible,
     reason for error termination.
*** Error element ID     863 has a zero normal vector.
E r r o r   t e r m i n a t i o n
s t o r a g e   a l l o c a t i o n
Memory required to complete solution   :      2849048
Additional dynamically allocated memory:       207569
                                   Total:      3056617
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Element processing ... 0.0000E+00    0.00     0.0000E+00    0.00
  Binary databases ..... 0.0000E+00    0.00     0.0000E+00    0.00
  ASCII database ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact algorithm .... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            0.0000E+00    0.00     0.0000E+00    0.00
Problem time       =    0.0000E+00
Problem cycle      =         0
Total CPU time     =         0 seconds (   0 hours  0 minutes  0 seconds)
CPU time per zone cycle  =         0 nanoseconds
Clock time per zone cycle=         0 nanoseconds
Number of CPU's    1
NLQ used/max      96/   96
Start time   11/03/2013 19:30:18
End time     11/03/2013 19:30:21
Elapsed time       3 seconds(  0 hours  0 min.  3 sec.) for       0 cycles
wanglieliangLv.2 显示全部楼层 发表于 2013-11-3 20:20
不能沉了啊,各位大神有没有遇到过这种情况,指教啊
863单元有问题,检查一下吧
wanglieliangLv.2 显示全部楼层 发表于 2013-11-4 13:51
863单元有问题,检查一下吧
谢谢论坛元老指导,我先研究研究怎么查看指定单元,刚学好多不懂
xiyuwuLv.3 显示全部楼层 发表于 2013-11-19 11:36
查找一下就可以找到了,
