[求助] 每日一问!(4)
zoe122208Lv.16 显示全部楼层 发表于 2009-9-8 17:59 |阅读模式 打印 上一主题 下一主题
老大帮我看看,这个热成形设置好了以后要运行的时候出现的问题,图在下面
精彩评论29
zoe122208Lv.16 显示全部楼层 发表于 2009-9-8 18:08
*** ERROR *** ISOTHERMAL CALCULATION:
IMPOSSIBLE TO IMPOSE TEMPERATURE
运算以后出现这个,是不是温度没有导进来,怎么样才能导进来温度呢
yanstillLv.12 显示全部楼层 发表于 2009-9-8 19:16
gravity下设置了温度了吗?
zoe122208Lv.16 显示全部楼层 发表于 2009-9-9 09:03
设置了,凸模120 凹模120 压边圈25 板料860
kofkillerLv.8 显示全部楼层 发表于 2009-9-9 09:42
这个多工序? 忘了设PICKING属性了??
yanstillLv.12 显示全部楼层 发表于 2009-9-9 20:01
把重力过程下的温度去掉,软件中重力过程是不考虑温度的
zoe122208Lv.16 显示全部楼层 发表于 2009-9-9 22:17
谢谢斑竹!
zoe122208Lv.16 显示全部楼层 发表于 2009-9-11 12:55
还是有问题,如果不设置温度,就说 重力过程必须设置温度,我采用picking的方式以后还是说Gravity will be isothermal 运算出现下面这些,老大帮帮忙。
     START TO READ IOSL INPUT FILE : E:\pam\练习\保险杠热冲\baoxiangang.pre
STARTING OF THE ANALYSIS : Gravity
SAVING THE SET-UP FILE : E:\pam\练习\保险杠热冲\baoxiangang_01_Gravity.pre
P O S I T I O N I N G   A C T I O N
  TRANSLATION ACTION .....: Initial Positioning of Blankholder
  POSITION OBJECT(S)......: Blank holder
  ALONG DIRECTION.........: 0,0,1
  WITH MAGNITUDE..........: 0
VALUE OF THE DISPLACEMENT = 0.000000e+000
  AUTOPOSITIONING ACTION .....: Blank Autopositioning
  ONTO OBJECT(S)..........: Blank holder , Punch
  WITH TOLERANCE..........: 0.001
VALUE OF THE DISPLACEMENT = 7.364951e+002
I O S L   I N F O R M A T I O N
     NUMBER OF OBJECTS         :     3
          OBJECT   ID     3  WITH  NAME  Punch
          OBJECT   ID     4  WITH  NAME  Blank holder
          OBJECT   ID    11  WITH  NAME  Blank
     --- AUXILLARY DEFINITION ---
     NUMBER OF CURVES          :    11
          CURVE    ID     5  WITH  NAME  HC
          CURVE    ID     6  WITH  NAME  curve_20
          CURVE    ID     7  WITH  NAME  curve_400
          CURVE    ID     8  WITH  NAME  curve_200
          CURVE    ID     9  WITH  NAME  curve_600
          CURVE    ID    10  WITH  NAME  curve_860
          CURVE    ID    16  WITH  NAME  BHforce_coef_-1
          CURVE    ID    17  WITH  NAME  velocity ramp curve
          CURVE    ID    18  WITH  NAME  H(d)
          CURVE    ID    12  WITH  NAME  cp_curve
          CURVE    ID    15  WITH  NAME  Constant value 0.00981 - Generated by IOSL
     NUMBER OF FRAMES          :     1
          FRAME    ID    19  WITH  NAME  press direction
     --- ATTRIBUTE DEFINITION ---
     NUMBER OF PARTS           :     3
          PART/MAT ID     3  ON OBJECT   Punch
          PART/MAT ID     4  ON OBJECT   Blank holder
          PART/MAT ID    11  ON OBJECT   Blank
     NUMBER OF CONTACTS        :     2
          CNTAC    ID    13  ON OBJECT   Punch
          CNTAC    ID    14  ON OBJECT   Blank holder
     NUMBER OF BOUNDARY COND.  :     2
          BOUNC              ON OBJECT   Punch
          BOUNC              ON OBJECT   Blank holder
     NUMBER OF ACCELERATIONS   :     1
          ACFLD              ON OBJECT   Blank
T I T L E
baoxiangang (01 : Gravity)
C O N T R O L   I N F O R M A T I O N
    NUMBER OF PARTS................................       3
    NUMBER OF MATERIALS............................       2
    NUMBER OF NODAL POINTS.........................    3757
    NUMBER OF 8-NODE SOLID ELEMENTS................       0
    NUMBER OF SHELL/MEMBRANE ELEMENTS..............    3886
    NUMBER OF TOTAL 1-D ELEMENTS ..................       0
    NUMBER OF 0-D ELEMENTS (PARTICLES) ............       0
    NUMBER OF MULTIBODY SYSTEMS....................       0
    NUMBER OF DISP. B.C. DEFINITIONS...............       2
    NUMBER OF NODAL TIME HISTORY DEFINITIONS ......       0
    NUMBER OF ELEMENT TIME HISTORY DEFINITIONS ....       0
    NUMBER OF B.C. ON POINTS DEFINITION............       0
    NUMBER OF LOCAL COORDINATE FRAMES..............       1
    NUMBER OF AIRBAGS .............................       0
    NUMBER OF PLIES IN COMPOSITE PLIES DATABASE....       0
    NUMBER OF RIGID BODY DEFINITIONS...............       0
    NUMBER OF SECTIONS FOR TRANSMISSION FORCES.....       0
    NUMBER OF LOAD CURVES..........................      11
    NUMBER OF LOOK UP TABLES.......................       0
    NUMBER OF CONCENTRATED LOAD CARDS..............       0
    NUMBER OF FACE PRESSURE CARDS..(SOLIDS/SHELLS).       0
    NUMBER OF BEAM PRESSURE CARDS..(BEAMS).........       0
    NUMBER OF VELOCITY CARDS.......................       0
    NUMBER OF USER-DEFINED GAS CARDS ..............       0
    NUMBER OF NODES WITH ADDITIONAL MASSES.........       0
    NUMBER OF RIGID WALL DEFINITIONS...............       0
    NUMBER OF CONSTRAINT CARDS.....................       0
    NUMBER OF INITIAL VELOCITIY CARDS..............       0
          EQ.0,  VELOCITIES ARE INITIALIZED TO ZERO
          GT.0,  INITIAL VELOCITIES ARE READ IN
    NUMBER OF SLIDING SURFACES.....................       2
    NUMBER OF RUPTURE MODELS.......................       0
    NUMBER OF FRICTION MODELS......................       0
    NUMBER OF PRESCRIBED ACCELERATION FIELDS.......       1
    NUMBER OF FLUID FORMING CELL DEFINITIONS.......       0
    NUMBER OF PLINK - SPOTWELD DEFINITIONS.........       0
    NUMBER OF TIED CONNECTION INTERFACES...........       0
    NUMBER OF SLINK - SURFACE LINK DEFINITIONS.....       0
    NUMBER OF ELINK - EDGE LINK DEFINITIONS........       0
    NUMBER OF LLINK - LINE LINK DEFINITIONS........       0
    NUMBER OF SENPT - SENSOR POINT DEFINITIONS.....       0
    NUMBER OF NSMAS - NONSTRUCTURAL MASS...........       0
    NUMBER OF MSTRM - MASS TRIM DEFINITION.........       0
    NUMBER OF DELEM - ELEMENT ELIMINATION CARDS ...       0
    NUMBER OF SENSORS..............................       0
    NUMBER OF BELT SLIPRINGS.......................       0
    NUMBER OF RETRACTORS...........................       0
    NUMBER OF MUSCLES..............................       0
    NUMBER OF FAST BELT SYSTEMS....................       0
    NUMBER OF GAUGES (ACCEL. IN LOCAL FRAME).......       0
    NUMBER OF NODAL DAMPING GROUPS.................       0
    NUMBER OF 3-D DRIVEN ACCELERATION CARDS .......       0
    NUMBER OF 3-D DRIVEN VELOCITY CARDS ...........       0
    NUMBER OF 3-D DRIVEN DISPLACEMENT CARDS .......       0
    NUMBER OF 3-D DRIVEN ANGULAR ACCEL. CARDS .....       0
    NUMBER OF 3-D DRIVEN ANGULAR VELOCITY CARDS ...       0
    NUMBER OF 3-D DRIVEN ANGULAR DISPL. CARDS .....       0
    NUMBER OF 3-D DRIVEN MIN DISPLACEMENT CARDS ...       0
    NUMBER OF 3-D DRIVEN MAX DISPLACEMENT CARDS ...       0
    NUMBER OF SUBSTRUCTURE DEFINITIONS ............       0
    NUMBER OF TRANSFORMATION DEFINITIONS ..........       0
    NUMBER OF FREEZE DEFINITION....................       0
    NUMBER OF DETONATION POINTS....................       0
    NUMBER OF ELEMENT MOMENTUM DEPOSITIONS(SOLIDS).       0
    NUMBER OF NODAL MOMENTUM DEPOSITIONS...........       0
    NUMBER OF ELEMENT MASS DEPOSITIONS(SOLIDS).....       0
    NUMBER OF ELEMENT ENERGY DEPOSITIONS(SOLIDS)...       0
    NUMBER OF TARVER CARDS(SOLIDS).................       0
    NUMBER OF CFD PRESSURE SURFACE DEFINITIONS.....       0
    TERMINATION TIME ..............................  0.10E+10
    TIME HISTORY PLOT INTERVAL VALUE ..............  0.10E+01
    MESH PLOT INTERVAL VALUE ......................  0.10E+10
    RESTART DUMP AT................................  0.00E+00
    NUMBER OF CYCLES BETWEEN RESTART DUMPS.........         0
    NUMBER OF RUNNING RESTART FILES................         1
    CYCLE LOG FREQUENCY............................        10
    INITIAL TIME STEP SIZE.........................  0.00E+00
          EQ.0.0, INITIAL TIME STEP COMPUTED INTERNALLY
    USER PREFERED TIME STEP .......................  0.00E+00
          EQ.0.0, TIME STEP COMPUTED BY PROGRAM
    FLAG FOR STRAIN RATE ACTIVATION ...............         1
          EQ. 0,  ALL STRAIN RATES SWITCHED ON (DEFAULT)
          EQ. 1,  ALL STRAIN RATES SWITCHED OFF
    STRAIN RATE FILTER INTERVAL IN CYCLES..........         0
          EQ. 0  TOTAL STRAIN RATE WITHOUT FILTER APPLIED
          EQ. 1  PLASTIC STRAIN RATE WITHOUT FILTER
          GT. 1  PLASTIC STRAIN RATE WITH DEFINED FILTER CYCLES
    STRAIN RATE CURVE INTERPOLATION FLAG ..........         0
          EQ. 0  LINEAR
          EQ. 1  LOGARITHMIC
      TIME STEP SCALE FACTOR.................  0.100E+01
      VELOCITY SCALING FACTOR (STRAIN RATE)..  0.100E+01
      METAL-FORMING SPRING BACK FLAG ........          1
      TOTAL STRAIN CALCULATION IS BASED ON LAGRANGIAN METHOD
         (DEFAULT IS INCREMENTAL)
      NODAL MASS OPTION .....................          1
         EQ. 0 : STANDARD
         EQ. 1 : SIMPLIFIED MASS
      STRAIN ORDER FORMULATION ..............          1
      THICKNESS INTEGRATION SCHEME ..........          1
         EQ. 0 : UNIFORM
         EQ. 1 : GAUSS
      SHELL TIME STEP OPTION:
       IN PLANE .............................          0
         EQ. 0 : LARGE
         EQ. 1 : SMALL
       BENDING  .............................         -1
         EQ. 0 : BEND
         EQ. 1 : NOBEND
         EQ.-1 : BEND LARGE
R U N   E N D   C R I T E R I A
      PROGRESSION IS TIME
I M P L I C I T   P A R A M E T E R S
      NUMBER OF INCREMENTS.........................1000000000
      MAXIMUM NUMBER OF NEWTON ITERATIONS..........        20
      DISPLACEMENT CONVERGENCE TOLERANCE........... -0.100E+00
      ENERGY CONVERGENCE TOLERANCE................. -0.100E+02
      MAXIMUM NB. OF PCG ITERATIONS SCALING FACTOR.  0.167E+00
      PCG CONVERGENCE TOLERANCE.................... -0.100E-03
      GRAVITY DAMPING SCALE FACTOR ................  0.100E+01
      SOLVER TYPE..................................         1
        -2 : MUMPS DIRECT OUT-OF-CORE SOLVER
        -1 : MUMPS DIRECT             SOLVER
         0 : PCG                      SOLVER
        DEFAULT SOLVERS
          1 : DEFAULT  DIRECT    SYMMETRIC     DOUBLE PRECISION
          3 : DEFAULT  ITERATIVE SYMMETRIC     DOUBLE PRECISION
T E M P E R A T U R E   C O N T R O L   P A R A M E T E R S
    FOURIER NUMBER ................................    0.9000E+00
    NUMBER OF INITIAL NODAL TEMPERATURE CARDS .....       1
    NUMBER OF IMPOSED BC NODAL TEMPERATURE CARDS ..       0
    NUMBER OF IMPOSED BC NODAL FLUX CARDS .........       0
    NUMBER OF THERMAL PROPERTY SET CARDS ..........       1
O P T I O N A L   S E C T I O N
    SOLVER                     STAMP
    SIGNAL                       YES
    DATA CHECK                    NO
    SHELL CHECK                   NO
    SOLID CHECK                   NO
    SOLID4N                       NO
    AIRBAG CHECK                  NO
    METRIC CHECK                  NO
    MAX. RESTART DUMP              1
    PIPE                          NO
    DEBUG                         NO
    RUN CHECK                     NO
    RWALL KINEMATIC CHECK        YES
    UNIT SYSTEM
      LENGTH              MM
      MASS                KG
      TIME                MS
      TEMPERATURE         KELV
O U T P U T   P A R A M E T E R S
    OUTPUT FILE E:\pam\练习\保险杠热冲\baoxiangang_01_Gravity
    PRINT                  NO
    GLOBAL HISTORY OUTPUT
      TOTAL CONTACT ENERGY
      CONTACT FORCE
    NODAL PLOT OUTPUT
      CONTACT PRESSURE
    SPH PLOT OUTPUT
    SOLID PLOT OUTPUT
      STRESS
    SHELL PLOT OUTPUT
      THICKNESS
      STRAIN TENSOR
      STRESS TENSOR
      MEMB. EQUIV. STRESS
      MEMB. PLASTIC STRAIN
    SHELL HISTORY OUTPUT
      THICKNESS
      STRAIN TENSOR
      STRESS TENSOR
      MEMB. EQUIV. STRESS
    BEAM PLOT OUTPUT
    PREFILTER                NO
N O D A L  P O I N T  C O O R D I N A T E S
        NP               X-ORD       Y-ORD       Z-ORD
====  DATA SUPPRESSED BY NOPRINT OPTION  ====
P L A T E / M E M B R A N E  E L E M E N T S
  ELEMENT    NODE1    NODE2    NODE3    NODE4  NINT THICK/ANGLE       ANGLE
     NUMBER OF QUAD OR TRIANGULAR ELEMENTS                =     3886
     NUMBER OF MEMBRANE ELEMENTS                          =        0
     NUMBER OF THICK SHELL ELEMENTS                       =        0
     NB. OF SHELLS: THK INT. PTS OF PART CARD OVERWRITTEN =     3886
     NB. OF SHELLS: THICKNESS OF PART CARD OVERWRITTEN    =        0
T A B U L A T E D  F U N C T I O N S
     NUMBER OF TABULATED FUNCTIONS       =   11
*** ERROR *** LOAD CURVE         5 LESS THAN 2 PTS.
blank
     THERMAL PROPERTY SET NUMBER .......=    1
     THERMAL MODEL .....................=    0
     SPECIFIC HEAT (CONSTANT) ......... =  0.0000E+00
     SPECIFIC HEAT (LOAD CURVE) ....... =          12
     THERMAL CONDUCTIVITY (CONSTANT)... =  0.3600E+02
     REFERENCE ENTHALPY.................=  0.0000E+00
     ENTHALPY (LOAD CURVE)............. =           0
     CONVERSION FACTOR................. =  0.1000E-08
     (DEFAULT=0.9)
L O C A L  C O O R D I N A T E   F R A M E S
     LOCAL FRAME NUMBER                  19
     FRAME ORIENTATION TYPE               1
       = 0 : FRAME ATTACHED TO ENTITY
       = 1 : FIXED FRAME
       = 2 : SELF-ROTATED
     FRAME AXIS DEF. TYPE                 0
       = 0 : U BASED, VIA 2 VECTORS
       = 1 : U BASED, VIA 3 NODES
       = 2 : T BASED, VIA 2 VECTORS
       = 3 : T BASED, VIA 3 NODES
     X-COMPONENT OF VECTOR 1  -0.100000E+01
     Y-COMPONENT OF VECTOR 1   0.000000E+00
     Z-COMPONENT OF VECTOR 1   0.000000E+00
     X-COMPONENT OF VECTOR 2   0.000000E+00
     Y-COMPONENT OF VECTOR 2   0.100000E+01
     Z-COMPONENT OF VECTOR 2   0.000000E+00
     X-COMPONENT OF VECTOR 3   0.000000E+00
     Y-COMPONENT OF VECTOR 3   0.000000E+00
     Z-COMPONENT OF VECTOR 3  -0.100000E+01
M A T E R I A L   D E F I N I T I O N
SOLID MATERIAL MODELS
     EQ.1   ELASTIC-PLASTIC
     EQ.2   SOIL AND CRUSHABLE FOAM MODEL
     EQ.5   VISCOELASTIC
     EQ.6   JWL HIGH EXPLOSIVE
     EQ.7   HYDRODYNAMIC-ELASTIC-PLASTIC
     EQ.8   STEINBERG - GUINAN MODEL
     EQ.9   TARVER REACTIVE BURN
     EQ.11  BLATZ-KO RUBBER MODEL
     EQ.12  JOHNSON-COOK MODEL
     EQ.14  DATA BASE EOS
     EQ.15  CRACKABLE BRITTLE-REINFORCED CONCRETE MODEL
     EQ.16  ELASTIC-PLASTIC WITH DAMAGE AND FAILURE
     EQ.17  MOONEY-RIVLIN RUBBER (with Hysterisis Option)
     EQ.18  HART-SMITH HYPERELASTIC RUBBER
     EQ.19  PRONY SERIES MOONEY-RIVLIN RUBBER
     EQ.20  POLYURETHANE FOAM
     EQ.21  HIGHLY COMPRESSIBLE URETHANE FOAM
     EQ.22  VISCOUS FOAM
     EQ.24  INELASTIC CRUSHABLE FOAM WITH HYSTERESIS
     EQ.25  SPECIFIC FOAM FOR SIDE IMPACT BARRIER
     EQ.26  ELASTIC-PLASTIC WITH GURSON DAMAGE
     EQ.28  MURNAGHAN EOS
     EQ.30  ORTHOTROPIC BI-PHASE
     EQ.31  NON LINEAR FIBER BI-PHASE
     EQ.35  IMPROVED FLECK FOAM MODEL
     EQ.36  ELASTIC-PLASTIC WITH ELASTIC STIFFENING
     EQ.37  VISCOELASTIC OGDEN MODEL, G VISCOUS MODEL
     EQ.40  NO LONGER SUPPORTED
     EQ.41  ADVANCED HONEYCOMB SIDE IMPACT BARRIER
     EQ.42  ORTHOTROPIC/ISOTROPIC MATERIAL
     EQ.45  GENERAL FOAM MODEL
     EQ.46  KARMANN FOAM MODEL (based on Seeliger-Dubois model)
     EQ.47  COMFORT FOAM MODEL
     EQ.51  ELASTIC WITH TLF AND THERMAL DILATATION
     EQ.52  ELASTIC-PLASTIC SOLID WITH FAILURE CRITERION OF KOLMOGOROV-DELL
     EQ.61  ELASTIC FOR BRICK SHELL
     EQ.62  ELASTIC-PLASTIC FOR BRICK SHELL
     EQ.71  EWK RUPTURE MODEL - SOLID ELEMENT VERSION
     EQ.99  NULL MATERIAL
     EQ.80  USER-DEFINED MATERIAL (ESI EXAMPLE)
     EQ.81  USER-DEFINED ELASTIC-PLASTIC MATERIAL
     EQ.82  USER-DEFINED MATERIAL (ESI EXAMPLE)
     EQ.83  ELASTIC-PLASTIC MATERIAL WITH JC FAILURE
SHELL MATERIAL MODELS
     EQ.100 NULL MATERIAL
     EQ.101 ELASTIC
     EQ.102 ELASTIC-PLASTIC
     EQ.103 ELASTIC-PLASTIC ITERATIVE
     EQ.105 ELASTIC-PLASTIC ISOTROPIC DAMAGE
     EQ.106 ELASTIC-PLASTIC ANISOTROPIC DAMAGE
     EQ.117 ANISOTROPIC ELASTIC-PLASTIC(STAMPING ORIENTED)
     EQ.108 ANISOTROPIC ELASTIC-PLASTIC ITERATIVE
     EQ.109 ALUMINIUM ANISOTROPIC ELASTIC-PLASTIC
     EQ.110 SUPERELASTIC MATERIAL
     EQ.115 ELASTIC-PLASTIC WITH GURSON DAMAGE
     EQ.116 TENSION-COMPRESSION ELASTIC-PLASTIC WITH DAMAGE
     EQ.118 ANISOTROPIC ELASTIC-PLASTIC WITH GURSON DAMAGE
     EQ.120 SUPERPLASTIC MATERIAL
     EQ.121 PLASTIC FORMING VISCO-ELASTIC MATERIAL
     EQ.122 OGDEN HYPERELASTIC MATERIAL
     EQ.128 ANISOTROPIC ELASTIC-PLASTIC MATERIAL WITH COMBINED INSTABILITY/DUCTILE/SHEAR FAILURE
     EQ.130 ORTHOTROPIC MULTILAYERED
     EQ.131 SANDWICH COMPOSITE
     EQ.132 FABRIC COMPOSITE
     EQ.140 THERMO-VISCO-ELASTIC MATRIX,  ELASTIC FIBERS
     EQ.143 ELASTIC-PLASTIC WITH ELASTIC STIFFENING
     EQ.150 ELASTIC MEMBRANE
     EQ.151 NONLINEAR MEMBRANE
     EQ.152 ELASTIC KNITTED MEMBRANE
     EQ.161 ELASTIC FOR THICK SHELL
     EQ.162 ELASTIC-PLASTIC FOR THICK SHELL
     EQ.171 EWK RUPTURE MODEL - SHELL ELEMENT VERSION
     EQ.180 USER-DEFINED MATERIAL (ESI EXAMPLE)
     EQ.181 USER-DEFINED ELASTIC-PLASTIC MATERIAL
     EQ.182 ORTHOTROPIC ELASTIC-PLASTIC MATERIAL (ESI)
     EQ.183 ELASTIC-PLASTIC MATERIAL WITH JC FAILURE
     EQ.184 USER-DEFINED MATERIAL (ESI EXAMPLE)
BAR/BEAM MATERIAL MODELS
     EQ.200 NULL MATERIAL
     EQ.201 ELASTIC (BEAM/BAR)
     EQ.202 ELASTIC-PLASTIC (BAR)
     EQ.203 IMPOSED FORCE-DISPLACEMENT (BAR)
     EQ.204 NONLINEAR SPRING-DASHPOT (BAR)
     EQ.205 SEAT BELT WEBBING MATERIAL (BAR)
     EQ.212 IMPROVED ELASTIC-PLASTIC (BEAM)
     EQ.213 ARBITRARY SECTION (BEAM)
     EQ.214 STEERING COLUMN BEAM
     EQ.220 6-DOF SPRING
     EQ.221 SPHERICAL (CARDAN) JOINT
     EQ.222 FLEXION-TORSION JOINT
     EQ.223 6-DOF SPRING-BEAM
LINK MATERIAL MODELS
     EQ.301 SLINK/ELINK, TIED SURFACE MATERIAL
     EQ.302 PLINK MATERIAL
     EQ.303 TIED SURFACE MATERIAL WITH DELAMINATION
     EQ.304 ORTHOTROPIC PLASTIC TIED CONNECTION
     *** ERROR *** OCCURRED IN INPUT PHASE, SEE ABOVE
kofkillerLv.8 显示全部楼层 发表于 2009-9-11 13:04
*** ERROR *** LOAD CURVE         5 LESS THAN 2 PTS. ?????????
CAELv.3 显示全部楼层 发表于 2009-9-11 14:26
学习下!!!
