[求助] 老大帮忙
zoe122208Lv.16 显示全部楼层 发表于 2009-10-12 16:49 |阅读模式 打印 上一主题 下一主题
老大,我设置好了以为,用内置求解器开始计算的时候,不到5秒钟出现psolid.exe错误,退出,用外置求解器计算的时候算一会就算不下去了,但是用外置求解器的双精度计算的话就可以算,这是何种原因呢
精彩评论13
kofkillerLv.8 显示全部楼层 发表于 2009-10-12 22:11
算的什么啊?
kofkillerLv.8 显示全部楼层 发表于 2009-10-13 07:09
算的什么啊?
zoe122208Lv.16 显示全部楼层 发表于 2009-10-13 18:33
冷冲,没什么特别的
kofkillerLv.8 显示全部楼层 发表于 2009-10-13 19:38
有空吧PRE发到我邮箱。我帮你看看
zoe122208Lv.16 显示全部楼层 发表于 2009-10-14 08:50
好的,到时候我把解决方案发上来,今天早上发现没有进行冲压就结束了,只到压边
zoe122208Lv.16 显示全部楼层 发表于 2009-10-14 09:54
MAX PLAS STRAIN (NOT ACTIVE IF 0.) =  0.0000E+00
  B O U N D A R Y  C O N D I T I O N S
NODES WITH BOUNDARY CONDITIONS
             NODE NO.     CONDITION                  NORMALIZED GIVEN SKEW VECTORS                  SENSOR
====  DATA SUPPRESSED BY NOPRINT OPTION  ====
====  TOTAL NUMBER OF B.C. APPLICATION NODES =   2604
  A C C E L E R A T I O N   F I E L D S
     ACCELERATION FIELD NO.   13
               NUMBER OF NODES .................     1800
               LOAD CURVE NUMBER FOR X-ACCEL. ..        0
               CURVE MULTIPLIER ................  0.0000E+00
               LOAD CURVE NUMBER FOR Y-ACCEL. ..        0
               LOAD CURVE NUMBER FOR Z-ACCEL. ..        9
               CURVE MULTIPLIER ................ -0.1000E+01
               LIST OF NODES:
S L I D I N G  S U R F A C E S  &  V O I D S
    SLIDING INTERFACE MODELS
       TYPE.EQ.1   SLIDING WITHOUT SEPARATION
       TYPE.EQ.10  SOLID STABILIZATION CONTACT
       TYPE.EQ.15  FAST PENALTY NODE-TO-SEGMENT CONTACT
                   FOR STAMPING (3D BUCKET SEARCH)
       TYPE.EQ.16  HYDRO-FORMING INTERFACE
       TYPE.EQ.17  NODE-TO-SEGMENT CONTACT FOR IMPLICIT APPL
                   (2D BUCKET SEARCH)
       TYPE.EQ.19  QUIKSTAMP CONTACT INTERFACE
       TYPE.EQ.21  BODY-TO-MULTIPLANE CONTACT
       TYPE.EQ.33  SYMETRIC MASTER-SLAVE CONTACT WITH:
                   NODE-SEGMENT AND NODE-EDGE TREATMENT
       TYPE.EQ.34  NON-SYMETRIC MASTER-SLAVE CONTACT WITH:
       TYPE.EQ.36  SELFIMPACTING CONTACT WITH:
       TYPE.EQ.37  SELFIMPACTING CONTACT FOR AIRBAG WITH:
                   NODE-SEGMENT, NODE-EDGE AND EDGE-EDGE TREATMENT
       TYPE.EQ.43  MASTER-SLAVE EDGE-EDGE CONTACT
       TYPE.EQ.44  HIGHER-ORDER NODE TO SEGMENT CONTACT
       TYPE.EQ.46  SELFIMPACTING CONTACT WITH:
                   EDGE-EDGE TREATMENT
       TYPE.EQ.54  NON-SYMETRIC MASTER-SLAVE CONTACT WITH:
                   ZERO CONTACT THICKNESS NODE-SEGMENT AND NODE-EDGE TREATMENT
S L I D E   L I N E   D E F I N I T I O N  N O.        1
       SLIDE LINE NAME ....................... Blank / Punch
       SLIDE LINE IDENTIFIER..................             7
       SLIDE LINE TYPE........................            17
       FRICTION FACTOR........................    0.0000E+00
       MASTER & SLAVE SEGMENT THICKNESS.......    0.1000E+01
       ACTIVATION TIME........................    0.0000E+00
       DEACTIVATION TIME......................    0.0000E+00
       SWITCHING SENSOR NUMBER ...............             0
       CONTACT INCREMENT NUMBER...............             1
       SCALE FACTOR FOR PENALTY...............    0.3000E-01
       MASTER ORIENTATION.....................             3
       VARIABLE THICKNESS FLAG ACTIVATED......
       ***** INPUT FOR S L A V E SURFACE ID.         7 *****
       ***** INPUT FOR M A S T E R SURFACE ID.         7 *****
S L I D E   L I N E   D E F I N I T I O N  N O.        2
       SLIDE LINE NAME ....................... Blank / Blank holder
       SLIDE LINE IDENTIFIER..................             8
       ***** INPUT FOR S L A V E SURFACE ID.         8 *****
       ***** INPUT FOR M A S T E R SURFACE ID.         8 *****
F L E X I B L E  T O K E N  S Y S T E M
  1 - FUNCTION SET: AUT_S_01
      SUB-DOMAIN  : MF_STAMP
      AGREEMENT   : NEEDED
      TOKENS      : 13
  2 - CPU CORE    :
      TOKENS      : 5
  TOTAL TOKEN NUMBER: 18
*** WARNING *** LOAD CURVE       10 IS NOT USED.
*** WARNING *** LOAD CURVE       11 IS NOT USED.
*** WARNING *** LOAD CURVE       12 IS NOT USED
*** INFO *** TABLE FOR KINEMATIC CHECK OPTION :
                      R R M M M M M R L A V D R R R X X X B N S
                      B B B B B T T W I C E I A V A A V D O O L
                      O C S C B O O A N C L S C E N C E I U D I
                      D O Y O B C I L C 3 3 3 3 3 3 3 3 3 N C P
                      Y G S G O O N L O D D D D D D D D D C O R
           RBODY   :  1 1 1 1 1 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1
           RBCOG   :  1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
           MBSYS   :  1 1 1 1 1 1 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1
           MBCOG   :  1 0 1 1 0 1 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1
           MBBBO   :  1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
           MTOCO   :  1 0 1 1 0 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1
           MTOIN   :  0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
           RWALL   :  1 0 0 0 0 1 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1
           LINCO   :  1 0 1 1 0 1 0 1 1 1 1 1 1 1 1 1 1 1 0 0 1
           XXX3D   :  1 0 1 1 0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0 1
           BOUNC   :  1 0 1 1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 1
           NODCO   :  1 0 1 1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 1 1
           SLIPR   :  1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
*** INFO *** MEMORY ALLOCATION AFTER INPUT PHASE :
     TOTAL PEAK MEMORY USED ..........      1.89 Mbytes
     TOTAL ACTUAL MEMORY NEEDED ......      1.70 Mbytes
*** INFO *** MINIMUM NODAL INERTIA =  0.324E-10
       SLIDE LINE NAME ......................NAME  Blank / Punch
       IDENTIFIER NO...........................ID              7
       SLIDE LINE TYPE........................NTY             17
       NO. OF SLAVE SEGMENTS.................NRTS           1721
       NO. OF MASTER SEGMENTS................NRTM           2074
       NO. OF SLAVE NODES.....................NSN           1800
       NO. OF MASTER NODES....................NMN           1919
       ACTUAL CONTACT THICKNESS...............THK     1.0000E+00
       DOMAIN BOX NUMBER FOR MASTER SURFACE:    1485(    33*    45*     1)
       SLIDE LINE NAME ......................NAME  Blank / Blank holder
       IDENTIFIER NO...........................ID              8
       NO. OF MASTER SEGMENTS................NRTM            703
       NO. OF MASTER NODES....................NMN            685
       DOMAIN BOX NUMBER FOR MASTER SURFACE:     918(    27*    34*     1)
N O D A L  P O I N T  V E L O C I T I E S
      NP         X-VEL         Y-VEL         Z-VEL        RX-VEL        RY-VEL        RZ-VEL
P R I M A R Y   N O D A L   M A S S
     TOTAL PRIMARY NODE MASS ARRAY   XMS
     NODE
R I G I D   B O D Y   D E F I N I T I O N
M B S Y S   R I G I D_B O D Y   D E F I N I T I O N
T O T A L  M A S S  =   0.199264E+01
      CENTER OF GRAVITY :
           XC :   0.2003E+03
           YC :   0.3266E+03
           ZC :   0.8613E+03
      ROTARY INERTIAS (TENSOR) :
           XX :   0.5424E+05
           YY :   0.9268E+04
           ZZ :   0.6256E+05
           XY :   0.1215E+02
           YZ :   0.5313E+01
           ZX :   0.2033E+02
      PRINCIPAL INERTIAS :
           I1 :   0.6256E+05
           I2 :   0.5424E+05
           I3 :   0.9268E+04
      PRINCIPAL AXES :
                 -0.2442E-02   -0.1000E+01   -0.2703E-03
                 -0.9913E-04    0.2706E-03   -0.1000E+01
                  0.1000E+01   -0.2442E-02   -0.9980E-04
*** INFO *** MEMORY ALLOCATION AFTER INITIALISATION PHASE :
     TOTAL PEAK MEMORY USED ..........     11.35 Mbytes
     TOTAL ACTUAL MEMORY NEEDED ......     10.87 Mbytes
                    |********* START SOLUTION PHASE *********|
SOLUTION AT CYCLE      1
TIME........................... 0.0000E+00
TIME STEP...................... 0.1000E+01
KINETIC  ENERGY................ 0.0000E+00
INTERNAL ENERGY................ 0.0000E+00
EXTERNAL KINETIC ENERGY.(MRW).. 0.0000E+00
EXTERNAL WORK.................. 0.0000E+00
TOTAL ENERGY................... 0.0000E+00
AVERAGE X-VELOCITY............. 0.0000E+00
AVERAGE Y-VELOCITY............. 0.0000E+00
AVERAGE Z-VELOCITY............. 0.0000E+00
SOLID HOURGLASS ENERGY......... 0.0000E+00
BULK  VISCOSITY ENERGY......... 0.0000E+00
SHELL HOURGLASS ENERGY......... 0.0000E+00
CONTACT SPRING WORK............ 0.0000E+00
CONTACT FRICTION ENERGY........ 0.0000E+00
ENERGY ABSORBED BY RIGID WALL.. 0.0000E+00
EXTERNAL DAMPING WORK.......... 0.0000E+00
FRICTION WORK AT SLIPRINGS..... 0.0000E+00
NUMBER OF PCG ITERATIONS.......          0
CPU PER ZONE-CYCLE (MICROSEC)..       0.00
          INTERNAL  INTERNAL  INTERNAL   TRANSL.
PART ID  ENERGY 1  ENERGY 2  ENER TOT KIN. ENER  X-MOMENT  Y-MOMENT  Z-MOMENT
       4  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
       5  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
       6  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00  0.00E+00
A I R B A G  D A T A
N O D A L  D A T A
     N.P.     X-COOR     Y-COOR     Z-COOR      X-VEL      Y-VEL      Z-VEL     X-ACCL     Y-ACCL     Z-ACCL     N.P.
S M O O T H  P A R T I C U L E  D A T A
     ELE.        RHO          V          P        SIE          H       AUX1       AUX2
     ELE.      SIG-X      SIG-Y      SIG-Z     TAU-XY     TAU-YZ     TAU-ZX        EPS
E L E M E N T  D A T A            3-D   E L E M E N T S
    ELEMENT              SIG-X        SIG-Y        SIG-Z       TAU-XY       TAU-YZ       TAU-ZX          EPS    INT. PT.
    ELEMENT               AUXILIARY VARIABLES PRINTOUT
E L E M E N T  D A T A           T H I N  P L A T E S
   ELEMENT      THICKNESS         SIGM1        SIGM2        SIGM3         MAX EPX1    VMIS STRS    DAMAGE
E L E M E N T  D A T A           1 - D  E L E M E N T S
  CYCLE      TIME     TIME-STEP  ELEMENT     NO  DTMIN FAC.  KINETIC EN  INTERNAL EN   TOTAL EN  DTMIN NB.
      INITIALIZATION OF THE SOLVER, NDOF=        10800
      INITIALIZATION OF THE TOPOLOGY
      SYMBOLIC ASSEMBLY OF THE MATRIX
      FINISHING TOPOLOGY
      INITIALIZATION OF THE SYSTEM
      INITIALIZATION OF THE MATRIX
      FACTORIZATION OF THE SYSTEM
      SOLUTION OF THE SYSTEM
NEWTON ITERATION...............          1
DISPLACEMENT TOLERANCE......... 0.1000E+01
ENERGY TOLERANCE............... 0.1000E+01
NEWTON ITERATION...............          2
DISPLACEMENT TOLERANCE......... 0.2783E+00
NEWTON ITERATION...............          3
DISPLACEMENT TOLERANCE......... 0.6546E-01
ENERGY TOLERANCE............... 0.4865E+00
TIME........................... 0.1000E+01
DISPLACEMENT TOLERANCE......... 0.4270E-01
ENERGY TOLERANCE............... 0.4849E-01
TIME........................... 0.2000E+01
DISPLACEMENT TOLERANCE......... 0.5356E+00
ENERGY TOLERANCE............... 0.7257E+00
ENERGY TOLERANCE............... 0.1794E+00
ENERGY TOLERANCE............... 0.8807E+00
NEWTON ITERATION...............          4
NEWTON ITERATION...............          5
NEWTON ITERATION...............          6
NEWTON ITERATION...............          7
NEWTON ITERATION...............          8
NEWTON ITERATION...............          9
NEWTON ITERATION...............         10
NEWTON ITERATION...............         11
NEWTON ITERATION...............         12
NEWTON ITERATION...............         13
NEWTON ITERATION...............         14
NEWTON ITERATION...............         15
NEWTON ITERATION...............         16
NEWTON ITERATION...............         17
DISPLACEMENT TOLERANCE.........  NaN
ENERGY TOLERANCE...............  NaN
Process stopped with status 157
我把一些信息发上来了,大家帮我看看吧,以前没这样过呀
zoe122208Lv.16 显示全部楼层 发表于 2009-10-14 09:56
有3个warning我红色高亮了
zoe122208Lv.16 显示全部楼层 发表于 2009-10-14 09:59
这个是求解器的截图
