[求助] dynaform热冲压无法计算问题
凤凰鸟Lv.2 显示全部楼层 发表于 2010-8-19 16:53 |阅读模式 打印 上一主题 下一主题
模拟设置
我在做热冲压成形时,设置热耦合计算后,计算不能进行,message文件显示的内容为如下,还望各位高手指教啊
    ___________________________________________________
     |  Livermore  Software  Technology  Corporation   |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Version:  970          Date: 01/10/2005        |
     |  Revision: 5434a        Time: 18:01:01          |
     |    32 Bit IEEE Binary File                      |
     |  Licensed to:                                   |
     |  Platform   : PC WIN32(PCWIN)                   |
     |  OS Level   : WINDOWS SERVER 2003               |
     |  Hostname   : MT13                              |
     |  Precision  : Double precision (I8R8)           |
     |  Unauthorized use infringes LSTC copyrights     |
Input file: E:/DYNAFO~2/cip/HOTSTA~1/HOTSTA~1.DYN
The native file format       : 64-bit small endian
Memory size from command line:   268435456
JOBID : hot_stamping
Memory option                : AUTO selected
expanding   memory to   268435456
*** Error LS-DYNA failed to allocate    268435456 words of memory.
           Please use the memory option on the execute line.
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Element processing ... 0.0000E+00    0.00     0.0000E+00    0.00
  Binary databases ..... 0.0000E+00    0.00     0.0000E+00    0.00
  ASCII database ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact algorithm .... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            0.0000E+00    0.00     0.0000E+00    0.00
Problem time       =    0.0000E+00
Problem cycle      =         0
Total CPU time     =         0 seconds (   0 hours  0 minutes  0 seconds)
CPU time per zone cycle  =         0 nanoseconds
Clock time per zone cycle=         0 nanoseconds
Number of CPU's     0
NLQ used/max       96/    96
Start time   08/19/2010 16:30:28
End time     08/19/2010 16:30:28
Elapsed time        0 seconds (   0 hours  0 minutes  0 seconds)
E r r o r   t e r m i n a t i o n
精彩评论6
jiangjian0739Lv.12 显示全部楼层 发表于 2010-8-19 21:58
内存的问题,提交的时候,信息显示好像你内存填大了,你把数值改小一些试试
nanyuanLv.3 显示全部楼层 发表于 2010-9-26 14:12
谢谢你的提醒
ghmjsLv.3 显示全部楼层 发表于 2011-10-26 15:55
我也正在学习中!
桀杰高升Lv.3 显示全部楼层 发表于 2011-10-27 16:59
路过学习!!!!
canquedelanLv.2 显示全部楼层 发表于 2011-11-12 09:45
学习一下   有没有相关热冲压的资料啊   分享一下呗
