*** Warning Memory is set 717785 words short
increase the memory size to 82643200
expanding memory to 86143994 joints
*** Warning Memory is set 3500794 words short
increase the memory size to 86643200
*** Error LS-DYNA failed to allocate 86643200 words of memory.
Please use the memory option on the execute line.
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 1.5860E+03 4.10 1.5878E+03 4.11
Element processing ... 2.7369E+04 70.75 2.7256E+04 70.47
Binary databases ..... 1.1000E+01 0.03 9.7290E+00 0.03
ASCII database ....... 0.0000E+00 0.00 8.0900E-01 0.00
Contact algorithm .... 9.6050E+03 24.83 9.7087E+03 25.10
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 1.1500E+02 0.30 1.1376E+02 0.29
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 3.8686E+04 100.00 3.8676E+04 100.00
Problem time = 7.7962E-02
Problem cycle = 72187
Total CPU time = 38686 seconds ( 10 hours 44 minutes 46 seconds)
CPU time per zone cycle = 1443 nanoseconds
Clock time per zone cycle= 1443 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 08/28/2010 21:27:45
End time 08/29/2010 08:14:21
Elapsed time 38796 seconds( 10 hours 46 min. 36 sec.) for 72187 cycles
E r r o r t e r m i n a t i o n
我是个新手,刚接触DYNAFORM不久,在message里面出现了以上的错误信息,请大虾们帮忙解决。 |
