[求助] DF工艺切口
xherioLv.2 显示全部楼层 发表于 2011-4-7 10:51 |阅读模式 打印 上一主题 下一主题
前处理
高手们,请问下如果我要拉深的工件深度为70mm,可是我想在50mm的时候设置一个工艺切口,请问在DF中怎么操作和设置!真的很需要你无私的帮忙!
polozhengLv.2 显示全部楼层 发表于 2011-4-25 10:05
学习了。
kofkillerLv.8 显示全部楼层 发表于 2011-4-26 13:23
20mm就开口啊。不太合适吧,。
做肯定能做。。拉延做2次。。先50 。然后切开。在拉20
sdjnzwyLv.2 显示全部楼层 发表于 2011-4-26 13:57
3# kofkiller
版主我做crashform的时候不计算,问题如下,解释下哦
maximum adaptive levels including itself...........         3
adaptive birth time................................ 0.00000E+00
adaptive death time................................ 0.10000E+21
load curve to define adaptive frequency............         0
when defined override ADPFREQ
minimum element size allowed to be adapted......... 0.10000E+01
adaptive algorithm to be used......................         1
eq.1: posterori error check (more error)
eq.2: priori error check (more accurate)
# of uniform refinement............................         0
approach distance before doing refinement.......... 0.10000E+01
negative: refine if tooling penetrates blank
thickness option................................... 0.00000E+00
  > 0. thickness before doing refinement
  < 0. thickness ratio for refinement.
if memory used exceeds this percentage or number...         0
of the memory available stop adapting
maintain input orientation in forming contact......         0
a 1 activates this option
number of elements over 90-degree radius ..........        -1
(_FORMING_ type contact, adpene > 0 required)
*** Error can not open file ?adapt.inp on unit   55
