返回列表 发新帖
[求助] 热成型不能求解
李自立Lv.2 显示全部楼层 发表于 2011-4-22 10:53
*** INFO *** CHARACTERISTIC LENGTH OF 2-D ELEMENTS =   0.3136E+01
*** ERROR *** THERMAL CONTACT HAS BEEN SPECIFIED BETWEEN die / blank AND blank
FOR A PURE MECANICAL SIMULATION
*** ERROR *** THERMAL CONTACT HAS BEEN SPECIFIED BETWEEN holder / blank AND blank
*** ERROR *** THERMAL CONTACT HAS BEEN SPECIFIED BETWEEN punch / blank AND blank
     *** ERROR *** OCCURRED IN INPUT PHASE, SEE ABOVE
李自立Lv.2 显示全部楼层 发表于 2011-4-22 11:18
BAR/BEAM MATERIAL MODELS
     EQ.200 NULL MATERIAL
     EQ.201 ELASTIC (BEAM/BAR)
     EQ.202 ELASTIC-PLASTIC (BAR)
     EQ.203 IMPOSED FORCE-DISPLACEMENT (BAR)
     EQ.204 NONLINEAR SPRING-DASHPOT (BAR)
     EQ.205 SEAT BELT WEBBING MATERIAL (BAR)
     EQ.212 IMPROVED ELASTIC-PLASTIC (BEAM)
     EQ.213 ARBITRARY SECTION (BEAM)
     EQ.214 STEERING COLUMN BEAM
     EQ.220 6-DOF SPRING
     EQ.221 SPHERICAL (CARDAN) JOINT
     EQ.222 FLEXION-TORSION JOINT
     EQ.223 6-DOF SPRING-BEAM
LINK MATERIAL MODELS
     EQ.301 SLINK/ELINK, TIED SURFACE MATERIAL
     EQ.302 PLINK MATERIAL
     EQ.303 TIED SURFACE MATERIAL WITH DELAMINATION
     EQ.304 ORTHOTROPIC PLASTIC TIED CONNECTION
lywjsLv.2 显示全部楼层 发表于 2011-6-22 10:20
找能算热成型的license,网上down的斗只能算冷成型,热成型license没有
flypenguinLv.2 显示全部楼层 发表于 2011-6-24 11:45
license的问题
