这是求解时出现的问题,求解器晃就结束了,发现fort13里面的问题,这些问题怎么解决啊 ,帮帮我啊,快毕不了业了
maximum adaptive levels including itself........... 3
adaptive birth time................................ 0.00000E+00
adaptive death time................................ 0.10000E+21
load curve to define adaptive frequency............ 0
when defined override ADPFREQ
minimum element size allowed to be adapted......... 0.10000E+01
adaptive algorithm to be used...................... 1
eq.1: posterori error check (more error)
eq.2: priori error check (more accurate)
# of uniform refinement............................ 0
approach distance before doing refinement.......... 0.10000E+01
negative: refine if tooling penetrates blank
thickness option................................... 0.00000E+00
> 0. thickness before doing refinement
< 0. thickness ratio for refinement.
if memory used exceeds this percentage or number... 0
of the memory available stop adapting
maintain input orientation in forming contact...... 0
a 1 activates this option
number of elements over 90-degree radius .......... -1
(_FORMING_ type contact, adpene > 0 required) |
