单动的可以根据软件的图标就看得出来 单动主工具是凹模
那双动的主工具是什么 ?
无重力加载的主工具又是什么?
帮助里面三言两语带过了这个问题——“导入或选择主/从工具模型。用户可以导入*.nas、*.new等格式的文件”
希望版主和各位高手指点一下
{:soso_e181:}
还有我计算怎么出错啊 下面是提示:
Date: 07/17/2012 Time: 17:31:17
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Licensed to: |
| Platform : PC WIN32(PCWIN) |
| OS Level : WINDOWS XP |
| Hostname : lbingj |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: F:/DF0186~1/0716-~1/KAISHI~1/buchang/buchang.dyn
The native file format : 32-bit small endian
Memory size from command line: 78643200
Memory option : AUTO selected
expanding memory to 78643200
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 433808
expanding memory to 847616
expanding memory to 1203518
expanding memory to 1248518
expanding memory to 1278518
expanding memory to 2567942
*** Error line number 18 contains improperly formatted data
(This is line# 18 of file
F:\DF0186~1\0716-~1\KAISHI~1\buchang\buchang.dyn)
--------------------------------------------------------------line# 18 ---------
6 6.000 0.750 1 1 0 0 1
*** Error reading *INTERFACE_COMPENSATION card.
Open include file: ./blank0.tmp
Open include file: ./spbk.tmp
Open include file: ./reference0.tmp
Open include file: ./reference1.tmp
Open include file: ./rigid.tmp
expanding memory to 3215627
expanding memory to 3271259
expanding memory to 3326891
expanding memory to 3385208
expanding memory to 3443525
expanding memory to 3501842
expanding memory to 3668738
expanding memory to 3727055
CHECKING SHELL ELEMENT DATA
*** Error Shell element with ID= 1
has an undefined PID= 1
*** Error Shell element with ID= 4441
has an undefined PID= 2
*** Error Shell element with ID= 8813
has an undefined PID= 5
*** Error input data failed with: 4 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 0
Additional dynamically allocated memory: 0
Total: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 07/17/2012 17:31:17
End time 07/17/2012 17:31:20
Elapsed time 3 seconds ( 0 hours 0 minutes 3 seconds)
